Lenovo IdeaPad 300-17ISK Hard Drive Replacement
  1. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Bottom Back Cover: step 1, image 1 of 1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: step 2, image 1 of 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: step 2, image 2 of 2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • The hard drive is located at the bottom of the laptop.
  4. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: step 4, image 1 of 1
    • Unscrew the four 6mm Phillips #1 screws that hold the hard drive frame in place.
  5. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: step 5, image 1 of 1
    • Gently pick up the hard drive without pulling it completely out.
    • You shouldn't use excessive force because the hard drive is still attached to the motherboard.
  6. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: step 6, image 1 of 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: step 6, image 2 of 2
    • Use the spudger to disconnect the hard drive from it motherboard connector.
    • The connector should come right off without excessive force.
  7. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: step 7, image 1 of 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: step 7, image 2 of 2
    • Remove the four 3mm Phillips #1 screws, two on each side, that secure the hard drive in its protective frame.
    • These screws are different from the rest of the laptop screws. You can damage the drive using the wrong screws.
    • Lift the frame to separate it from the hard drive.
10 other people completed this guide.
Ammar Dodin
1,057 Reputation
6 Guides authored
UC Davis, Team 1-3, Rodger Winter 2017 Member of UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Members
6 Guides authored
3 Comments
Clear and easy - thanks!
Beth Pierce - Reply
Easy breezy.
danlord65 - Reply
Very good and to the point
al_stewart - Reply
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 38
All Time: 9,657
