Lenovo IdeaPad 3-15IML05 Battery Replacement
  1. Lenovo IdeaPad 3-15IML05 Battery Replacement, Lower Case: step 1, image 1 of 2 Lenovo IdeaPad 3-15IML05 Battery Replacement, Lower Case: step 1, image 2 of 2
    • Before beginning, discharge the battery below 25%, power the device off, and disconnect all peripherals.
    • Use a Phillips #1 screwdriver to remove the following screws:
    • Six 7 mm screws
    • Four 4 mm screws
  2. Lenovo IdeaPad 3-15IML05 Battery Replacement: step 2, image 1 of 2 Lenovo IdeaPad 3-15IML05 Battery Replacement: step 2, image 2 of 2
    • Insert an opening pick into the seam between the lower case and chassis.
    • Slide the pick around the entire perimeter until all of the plastic retaining clips release.
    • Remove the lower case.
    • Forcing the back cover open could break the plastic retaining clips.
    • During reassembly, lay the cover flat and press around the edges to secure it to the plastic clips.
  3. Lenovo IdeaPad 3-15IML05 Battery Replacement, Lenovo IdeaPad 3-15IML05 Battery Disconnection: step 3, image 1 of 2 Lenovo IdeaPad 3-15IML05 Battery Replacement, Lenovo IdeaPad 3-15IML05 Battery Disconnection: step 3, image 2 of 2
    • Use a plastic spudger or your fingernail to gently push the JST battery connector out of its socket.
    • Pulling directly on the cable could damage the connector.
  4. Lenovo IdeaPad 3-15IML05 Battery Replacement, Battery: step 4, image 1 of 2 Lenovo IdeaPad 3-15IML05 Battery Replacement, Battery: step 4, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws securing the battery.
    • To remove the battery, slide it to the right and lift it away from the hard drive cover.
    • If needed, you can lift the hard drive cover by removing the two 5 mm screws on the left.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 35
All Time: 291
