Introduction
If you are having audio issues such as static, distorted or just having no sound at all, your laptop speakers may be faulty and needs to be replaced. Use this guide to the replace your speakers in your Lenovo IdeaPad 1-14lGL05. The tools needed are a Philips #0 screwdriver and an opening tool.
Place the device on a flat surface with the lower case facing up.
Use a Phillips #0 screwdriver to remove the ten 3 mm-long screws that secure the lower case.
Use two opening tools or your fingernails to gently "walk" the speaker connector directly out of its motherboard socket.
For optimal performance, after completing this guide, calibrate your newly installed battery.
