Introduction
Disassembly of the laptop is required to remove the power jack.
Place laptop on a flat surface with the back cover facing up and the hinges facing you.
Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
Locate the CD drive.
Remove the single #00 Phillips 5.5 mm screw on the centermost side of the drive.
Locate the 3 screws on the bottom, securing the keyboard.
One Screw will be located under Lenovo sticker. Break sticker to gain access to screw.
Using tweezers, lift up clip to remove keyboard ribbon cable.
On some laptops the colors for the clips are reversed. You should lift up the inner piece. Took me 15 mind to figure out
Remove wifi wires by lifting up
The reattachment of these wires is tricky and not immediately obvious. The wires clip to the card by a small circular attachment male on the card female on the wire. I used a small flat head electrical screwdriver to push down the wires onto the card.
Begin by locating screws on bottom panel
Missing step. The hard drive needs to be removed. 4 screws then slide back (to left in above image)
11 other people completed this guide.
4 Comments
TY TY fixed myself for 7$
Should the new Power Jack look exactly the same as the manufacturer one? My original Power Jack has prongs but the new one does not and the laptop will not power on.
Does this require soldering as well ?
I would not rate this as a difficult task and I managed to complete the dismantle and reassemble within the 45 Minutes, Overall a pretty good description. The hardest bit was reattaching the wifi wires. I found I did not need tweezers and used a small electrical flat head instead of a spudge. No soldering or other tools. Having bought a new battery and charger (circa $50) the replacement part ($5) and this guide solved the issue. @gifts.fromgod my part was not identical (colour and size of the mid wire join) but fitted more or less and works a charm.
