Lenovo Flex 3-1580 Screen Replacement
  1. Lenovo Flex 3-1580 Screen Replacement, Screen: step 1, image 1 of 1
    • Open up the laptop so that the screen is facing you like in the picture.
  2. Lenovo Flex 3-1580 Screen Replacement: step 2, image 1 of 3 Lenovo Flex 3-1580 Screen Replacement: step 2, image 2 of 3 Lenovo Flex 3-1580 Screen Replacement: step 2, image 3 of 3
    • Use the black spudger to pry off the two rubber covers at the bottom right and left side of the laptop screen.
    • Remove the two 4.0 mm screws that were under the rubber covers using a JIS #0 screwdriver.
    • Pry off the plastic covers that you just unscrewed with the spudger.
    • Pry off the middle black plastic part with the spudger. Remove the 4.0 mm screw using a JIS #0 screwdriver.
  3. Lenovo Flex 3-1580 Screen Replacement: step 3, image 1 of 3 Lenovo Flex 3-1580 Screen Replacement: step 3, image 2 of 3 Lenovo Flex 3-1580 Screen Replacement: step 3, image 3 of 3
    • Pry off the backing of the screen with a spudger.
    • The screen will then fall off; however it will still be connected to the screen back plate like in picture 3.
  4. Lenovo Flex 3-1580 Screen Replacement: step 4, image 1 of 3 Lenovo Flex 3-1580 Screen Replacement: step 4, image 2 of 3 Lenovo Flex 3-1580 Screen Replacement: step 4, image 3 of 3
    • Peel off the tape and disconnect the yellow cable from the screen.
    • Follow the cable to unplug the smaller black plug in as seen in the second picture.
    • Follow the same cable all along the side of the screen and untape and disconnect the cable going into the camera.
Florence Hall
525 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 98
