Lenovo Flex 3-1580 Cooling Fan Replacement
  1. Lenovo Flex 3-1580 Cooling Fan Replacement, Back Cover: step 1, image 1 of 1
    • Remove eleven 6.0 mm screws from the bottom cover using a JIS #1 screwdriver.
  2. Lenovo Flex 3-1580 Cooling Fan Replacement: step 2, image 1 of 2 Lenovo Flex 3-1580 Cooling Fan Replacement: step 2, image 2 of 2
    • Loosen the backing cover by sliding a spudger along the edges.
    • You’ll hear and feel a pop as you loosen the edges. This lets you know the backing is loosening up.
    • Remove the bottom cover from the laptop.
  3. Lenovo Flex 3-1580 Cooling Fan Replacement, Cooling Fan: step 3, image 1 of 2 Lenovo Flex 3-1580 Cooling Fan Replacement, Cooling Fan: step 3, image 2 of 2
    • Loosen the five 6.0 mm screws with a JIS #1 screwdriver.
    • Release the cables from the guides.
  4. Lenovo Flex 3-1580 Cooling Fan Replacement: step 4, image 1 of 3 Lenovo Flex 3-1580 Cooling Fan Replacement: step 4, image 2 of 3 Lenovo Flex 3-1580 Cooling Fan Replacement: step 4, image 3 of 3
    • Remove the fan and heat sink by lifting upwards.
    • Unplug the fan connector pulling downwards.
    • Before installing a new fan, apply a pea-sized amount of thermal paste the the CPU.
    • When reinstalling, make sure the cables are not subjected to any tension. The tension can cause the cables to be damaged by the cable guides.
Florence Hall
525 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 91
