Lenovo Flex 3-1120 Hard Drive Replacement
  1. Lenovo Flex 3-1120 Hard Drive Replacement, Bottom Panel: step 1, image 1 of 1
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Hard Drive Replacement: step 2, image 1 of 2 Lenovo Flex 3-1120 Hard Drive Replacement: step 2, image 2 of 2
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Hard Drive Replacement: step 3, image 1 of 1
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Hard Drive Replacement: step 4, image 1 of 1
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
    • Locate the hard drive in the bottom left of your computer.
  6. Lenovo Flex 3-1120 Hard Drive Replacement: step 6, image 1 of 2 Lenovo Flex 3-1120 Hard Drive Replacement: step 6, image 2 of 2
    • Locate the three 3.5mm Phillips screws on the corners of the hard drive.
    • Remove the three screws with a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Hard Drive Replacement: step 7, image 1 of 1
    • Follow the wire out from the right side of the hard drive to locate where the hard drive connects to the motherboard.
  8. Lenovo Flex 3-1120 Hard Drive Replacement: step 8, image 1 of 1
    • Lift off the strip of tape securing the wire down to the computer.
  9. Lenovo Flex 3-1120 Hard Drive Replacement: step 9, image 1 of 1
    • Pull the connector out of its port on the motherboard.
  10. Lenovo Flex 3-1120 Hard Drive Replacement: step 10, image 1 of 1
    • Lift the hard drive out from the computer.
8 other people completed this guide.
Geoff Bentz
961 Reputation
5 Guides authored
4 Guide Comments
How do you reload operating system.... for example windows 10?
supermac200 - Reply
How do I get Windows 10 working again after replacing hard drive on Lenovo Flex 3?
arcinko - Reply
Demo models of this do not have any SATA connector.
Elilla Shadowheart - Reply
That sata connector is the worst thing ever
dilleremail - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 28
All Time: 11,371
