Lenovo Flex 2-15 Motherboard Replacement
  1. Lenovo Flex 2-15 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Begin by taking the back plate off of your device. Using a Phillips head screw driver, take out the highlighted screws for your device.
    Ask FixBot
  2. Lenovo Flex 2-15 Motherboard Replacement: step 2, image 1 of 1
    • Remove battery from the motherboard by unplugging the cord and removing the screws.
    Ask FixBot
  3. Lenovo Flex 2-15 Motherboard Replacement: step 3, image 1 of 1
    • Once you have the battery removed, locate the cable for your new battery and connect it on the same port from your old battery. Secure it onto the laptop by using the screws. After this step is complete, complete step 1 in reverse order to secure the plate cover over your motherboard.
    Ask FixBot
  4. Lenovo Flex 2-15 Motherboard Replacement, Keyboard: step 4, image 1 of 2 Lenovo Flex 2-15 Motherboard Replacement, Keyboard: step 4, image 2 of 2
    • Apply gentle pressure with the Philips #00 screwdriver through the hole to pop out the keyboard.
    • The hole in the red circle is a through hole to the back of keyboard. If pressure is applied the keyboard will pop off.
    Ask FixBot
  5. Lenovo Flex 2-15 Motherboard Replacement: step 5, image 1 of 1
    • Lift up the keyboard with your fingers.
    Ask FixBot
  6. Lenovo Flex 2-15 Motherboard Replacement: step 6, image 1 of 1
    • Flip up the black ZIF locking flap that secures the keyboard ribbon cable.
    • Disconnect the ribbon cable.
    • Remove the keyboard.
    Ask FixBot
  7. Lenovo Flex 2-15 Motherboard Replacement, Speaker: step 7, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the one 4 mm screw on the left speaker.
    Ask FixBot
  8. Lenovo Flex 2-15 Motherboard Replacement: step 8, image 1 of 1
    • Use a Phillips #00 screwdriver to disconnect the one 4 mm screw on the right speaker.
    Ask FixBot
  9. Lenovo Flex 2-15 Motherboard Replacement: step 9, image 1 of 2 Lenovo Flex 2-15 Motherboard Replacement: step 9, image 2 of 2
    • Disconnect the speaker the connector on the right speaker from the motherboard by pulling the connector out with your fingernail.
    Ask FixBot
  10. Lenovo Flex 2-15 Motherboard Replacement: step 10, image 1 of 1
    • Gently lift the two speakers out with your hands.
    Ask FixBot
  11. Lenovo Flex 2-15 Motherboard Replacement, Daughterboard: step 11, image 1 of 2 Lenovo Flex 2-15 Motherboard Replacement, Daughterboard: step 11, image 2 of 2
    • Flip up the black ZIF locking flap. Disconnect the ribbon cable.
    Ask FixBot
  12. Lenovo Flex 2-15 Motherboard Replacement: step 12, image 1 of 2 Lenovo Flex 2-15 Motherboard Replacement: step 12, image 2 of 2
    • Remove the two 4 mm Phillips #00 screws that secure the daughterboard.
    Ask FixBot
  13. Lenovo Flex 2-15 Motherboard Replacement: step 13, image 1 of 1
    • Grab the daughterboard with your fingers and lift it straight up and out of the chassis.
    Ask FixBot
  14. Lenovo Flex 2-15 Motherboard Replacement, SSD: step 14, image 1 of 1
    • Using a Phillips head screw driver, take out the highlighted screws for your device.
    Ask FixBot
  15. Lenovo Flex 2-15 Motherboard Replacement: step 15, image 1 of 2 Lenovo Flex 2-15 Motherboard Replacement: step 15, image 2 of 2
    • Locate the SSD bay for your device via the highlighted portion.
    Ask FixBot
  16. Lenovo Flex 2-15 Motherboard Replacement: step 16, image 1 of 1
    • Using the pull tab shown here, gently take the SSD out of its highlighted slot.
    Ask FixBot
  17. Lenovo Flex 2-15 Motherboard Replacement: step 17, image 1 of 2 Lenovo Flex 2-15 Motherboard Replacement: step 17, image 2 of 2
    • We will need to use a Phillips screwdriver to take the SSD out of its bay.
    Ask FixBot
  18. Lenovo Flex 2-15 Motherboard Replacement, Motherboard: step 18, image 1 of 3 Lenovo Flex 2-15 Motherboard Replacement, Motherboard: step 18, image 2 of 3 Lenovo Flex 2-15 Motherboard Replacement, Motherboard: step 18, image 3 of 3
    • Disconnect the fan connector from the motherboard.
    • Remove the three 4 mm screws that secure the heatsink with a Phillips #00 screwdriver.
    • Remove the heatsink carefully and set aside.
    • Do not strip the screws.
    • Do not bend the pins in the fan connector port.
    • You will need to reapply thermal paste before replacing the heatsink.
    Ask FixBot
  19. Lenovo Flex 2-15 Motherboard Replacement: step 19, image 1 of 1
    • Using your fingers, pinch the release levers on the side of the ribbon cable.
    • Remove the ribbon cable near the optical drive with your fingers.
    • Do not break the connector on the end of the cable.
    Ask FixBot
  20. Lenovo Flex 2-15 Motherboard Replacement: step 20, image 1 of 2 Lenovo Flex 2-15 Motherboard Replacement: step 20, image 2 of 2
    • Remove the 4 mm standoff screws in the motherboard with a Phillips #00 screwdriver.
    Ask FixBot
  21. Lenovo Flex 2-15 Motherboard Replacement: step 21, image 1 of 1
    • Flip up the black ZIF locking flap that secures the keyboard ribbon cable, then remove the cable.
    • Detach the keybribbon cable from the motherboard by prying with a spudger.
    Ask FixBot
  22. Lenovo Flex 2-15 Motherboard Replacement: step 22, image 1 of 1
    • Remove the 4 mm Phillips screw under the keyboard with the Phillips #00 screwdriver.
    Ask FixBot
  23. Lenovo Flex 2-15 Motherboard Replacement: step 23, image 1 of 1
    • Disconnect the two connector cables at the back of the motherboard with your fingers.
    Ask FixBot
  24. Lenovo Flex 2-15 Motherboard Replacement: step 24, image 1 of 2 Lenovo Flex 2-15 Motherboard Replacement: step 24, image 2 of 2
    • Remove the five 4 mm screws at the top of the motherboard using a Phillips #00 screwdriver.
    Ask FixBot
  25. Lenovo Flex 2-15 Motherboard Replacement: step 25, image 1 of 1
    • Remove the last standoff screw near the SSD drive with the Phillips #00 screwdriver.
    Ask FixBot
  26. Lenovo Flex 2-15 Motherboard Replacement: step 26, image 1 of 1
    • Gently lift and remove the motherboard from the laptop; there should be little resistance when removing it.
    • If you have difficulty removing the board, check that you have removed all connectors and ribbon cables connecting the board. You may also remove the SSD for additional ease.
    • Lay the motherboard on a nonconducting surface, this will prevent short circuiting.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 30
All Time: 310
