Introduction
RAM should be replaced if the computer has memory issues. This is sometimes the case when the computer won't boot, or simply runs too slow for comfort.
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
Using a spudger, push one of the metal rods on either side of the RAM stick away from it until you hear a light clicking noise. Repeat this procedure on the other metal rod on the opposite side of the RAM stick.
