Shop the Holiday Gift Guide
Lenovo Essential G560 RAM Replacement and install 4gb RAM
Views: 12K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
120
All Time:
12,313
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 5 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
RAM should be replaced if the computer has memory issues. This is sometimes the case when the computer won't boot, or simply runs too slow for comfort.
Parts
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Lenovo Essential G560 RAM Replacement and install 4gb RAM, Battery: step 1, image 1 of 1
      • Turn off the computer.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the cable could result in electric shock.
      • Flip the computer upside down.
      Ask FixBot
    2. Lenovo Essential G560 RAM Replacement and install 4gb RAM: step 2, image 1 of 2 Lenovo Essential G560 RAM Replacement and install 4gb RAM: step 2, image 2 of 2
      • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
      Ask FixBot
    3. Lenovo Essential G560 RAM Replacement and install 4gb RAM: step 3, image 1 of 1
      • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
      Ask FixBot
    1. Lenovo Essential G560 RAM Replacement and install 4gb RAM, Back Panel: step 4, image 1 of 1
      • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
      Ask FixBot
    2. Lenovo Essential G560 RAM Replacement and install 4gb RAM: step 5, image 1 of 2 Lenovo Essential G560 RAM Replacement and install 4gb RAM: step 5, image 2 of 2
      • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
      • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
      Ask FixBot
    3. Lenovo Essential G560 RAM Replacement and install 4gb RAM: step 6, image 1 of 1
      • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
      Ask FixBot
    1. Lenovo Essential G560 RAM Replacement and install 4gb RAM, RAM: step 7, image 1 of 2 Lenovo Essential G560 RAM Replacement and install 4gb RAM, RAM: step 7, image 2 of 2
      • Locate the RAM Sticks in the computer. They should be in the corner of the laptop.
      Ask FixBot
    2. Lenovo Essential G560 RAM Replacement and install 4gb RAM: step 8, image 1 of 2 Lenovo Essential G560 RAM Replacement and install 4gb RAM: step 8, image 2 of 2
      • Using a spudger, push one of the metal rods on either side of the RAM stick away from it until you hear a light clicking noise. Repeat this procedure on the other metal rod on the opposite side of the RAM stick.
      • If you push both metal rods away from the RAM stick as directed, the RAM stick will pop up at an angle.
      Ask FixBot
    3. Lenovo Essential G560 RAM Replacement and install 4gb RAM: step 9, image 1 of 1
      • Gently pull out the stick of RAM.
      • If you wish to remove the second stick of RAM, do so by following steps two and three again.
      Ask FixBot
5 other people completed this guide.
Author
with
Dennis Wong
618 Reputation
5 Guides authored
Cal Poly, Team 18-40, Regan Winter 2013 Member of Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Members
84 Guides authored
1 Guide Comment
maine apne lenovo g560 laptop me crucial 4gb ram add kiya lekin mera system format nahi ho raha h. mujhe kya karna chahiye mujhe email kare. vikasmaddeshiya056@gmail.com
vikkivikas056 - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 120
All Time: 12,313
