Introduction
This guide will teach you to replace the LCD screen of your laptop computer.
Remove the black plastic or rubber screw caps covering screws, located at the bottom of the screen
Slide LCD screen around the edges while pulling upwards so that it pops off.
Turn the screen over so the touch board is visible, and start working from the back of the screen.
That should be ‘slide a spudger around the LCD edges to release the hooks’. I’m so used to Lenovo’s where you have to slide the LCD up/down to unhook it from the back panel that I thought that here.
5 other people completed this guide.
4 Comments
Does the lcd separate from the digitizer screen or do both need to be replaced if the digitizer is cracked?
Typically one can separate the LCD from the glass, but it is a difficult and painful process, and it almost always cracks the LCD. If the cost is not prohibitively expensive, I would just replace them together as one unit.
I need that exact bottom frame strip piece replaced that they are showing in the first picture. Does anyone know where I can order one?
looking to replace the whole screen, if possible even the hinge.
nasty bent screen I have for over 2+ years and I want to change that. Any advice welcomed.
frame is bent, Glass is broken in corner, touch screen gone.
Wouldnt care to install digitizer back but if I can see how to install screen components that be good.
Carry on.
Do you know where I can buy that black strip? I need to replace that part.
Zarina - Reply
