Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement
Video Overview
  1. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Battery: step 1, image 1 of 1
    • Switch off the laptop, disconnect the AC adapter, and remove the battery.
  2. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: step 2, image 1 of 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: step 2, image 2 of 2
    • Remove the screws securing the Memory / HDD cover.
    • Slide the cover down and remove it.
  3. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: step 3, image 1 of 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: step 3, image 2 of 2
    • To pop up the memory module you’ll have to spread latches on both sides of the slot.
    • MEMORY
    • Speed 1600 MHz / PC3L-12800
    • Technology DDR3L SDRAM SODIMM
    • Max Supported Size 16 GB
    • Form Factor SO-DIMM 204-pin
    • Slots Qty 2
    • Empty Slots 1
  4. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): step 4, image 1 of 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): step 4, image 2 of 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): step 4, image 3 of 3
    • Remove two screws securing the hard drive mounting bracked.
    • Slide the HDD to the left to disconnect it from the motherboard and remove it from the device.
    • Remove two screws on each side of the HDD to remove the mounting bracket.
    • Now you have to transfer the mounting bracket to the new HDD or SSD.
  5. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: step 5, image 1 of 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: step 5, image 2 of 2
    • Remove the screw and disconnect the two coaxial antenna cables from the WiFi card.
    • Pop it up and remove it from the slot.
    • Wireless N M.2, or Next Generation Form Factor (NGFF) Card.
  6. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: step 6, image 1 of 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: step 6, image 2 of 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: step 6, image 3 of 3
    • Complementary Metal-Oxide-Semiconductor (CMOS) aka Real-Time Clock (RTC)
    • CR2032
  7. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement: step 7, image 1 of 1
    • That's all.
3 other people completed this guide.
ZFix
191,182 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,519 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 45
All Time: 7,231
