Lenovo 500e Chromebook 81ES USB Board Replacement
    1. Lenovo 500e Chromebook 81ES USB Board Replacement, Lower Case: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the ten 4 mm-long screws that secure the lower case.
      Ask FixBot
    2. Lenovo 500e Chromebook 81ES USB Board Replacement: step 2, image 1 of 2 Lenovo 500e Chromebook 81ES USB Board Replacement: step 2, image 2 of 2
      • Insert the flat end of a spudger into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. Lenovo 500e Chromebook 81ES USB Board Replacement, USB Board: step 3, image 1 of 2 Lenovo 500e Chromebook 81ES USB Board Replacement, USB Board: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the four 4 mm-long screws that secure the metal bracket over the USB board.
      Ask FixBot
    2. Lenovo 500e Chromebook 81ES USB Board Replacement: step 4, image 1 of 2 Lenovo 500e Chromebook 81ES USB Board Replacement: step 4, image 2 of 2
      • Remove the bracket.
      Ask FixBot
    3. Lenovo 500e Chromebook 81ES USB Board Replacement: step 5, image 1 of 2 Lenovo 500e Chromebook 81ES USB Board Replacement: step 5, image 2 of 2
      • Use the flat end of a spudger to flip up the two ZIF locking flaps on the USB board.
      • Disconnect the ribbon cables.
      Ask FixBot
    4. Lenovo 500e Chromebook 81ES USB Board Replacement: step 6, image 1 of 2 Lenovo 500e Chromebook 81ES USB Board Replacement: step 6, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the 2 mm-long screw that secures the USB board.
      Ask FixBot
    5. Lenovo 500e Chromebook 81ES USB Board Replacement: step 7, image 1 of 2 Lenovo 500e Chromebook 81ES USB Board Replacement: step 7, image 2 of 2
      • Lift the USB board up and out the chassis.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Connor Bassolino
25,896 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 43
All Time: 126
