Introduction
This guide will help you replace the touchpad in the Lenovo 500e Chromebook 81ES. If you are experiencing issues with the touchpad, including being unresponsive to inputs or having bad connections, follow this guide. For this guide, you will need a spudger, Phillips #0 screwdriver, and tweezers. Make sure the Chromebook is powered off and unplugged from the charger.
Use a Phillips #0 screwdriver to remove the ten 4 mm-long screws that secure the lower case.
Use a spudger to flip up the locking flap securing the lower I/O board ribbon cable to the motherboard.
Use a spudger to flip open the locking flap securing the touchpad ribbon cables.
Disconnect the touchpad ribbon cable.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
