Lenovo 500e Chromebook 81ES Motherboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
58
All Time:
293
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will help you replace the USB Ports in the Lenovo 500e Chromebook 81ES. If you are experiencing issues with the USB Ports, including damaged ports, bad connections, follow this guide. For this guide, you will need a spudger,  Phillips #0 screwdriver, and tweezers. Make sure the Chromebook is powered off and unplugged from the charger.
Tools
    1. Lenovo 500e Chromebook 81ES Motherboard Replacement, Lower Case: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the ten 4 mm-long screws that secure the lower case.
      Ask FixBot
    2. Lenovo 500e Chromebook 81ES Motherboard Replacement: step 2, image 1 of 2 Lenovo 500e Chromebook 81ES Motherboard Replacement: step 2, image 2 of 2
      • Insert the flat end of a spudger into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. Lenovo 500e Chromebook 81ES Motherboard Replacement, Battery: step 3, image 1 of 2 Lenovo 500e Chromebook 81ES Motherboard Replacement, Battery: step 3, image 2 of 2
      • Use a spudger to flip up the locking flap securing the lower I/O board ribbon cable to the motherboard.
      • The cable should be able to freely move back and forth. If not the plastic gate might not be fully unlocked.
      Ask FixBot
    2. Lenovo 500e Chromebook 81ES Motherboard Replacement: step 4, image 1 of 2 Lenovo 500e Chromebook 81ES Motherboard Replacement: step 4, image 2 of 2
      • Use tweezers to disconnect the battery connector.
      Ask FixBot
    3. Lenovo 500e Chromebook 81ES Motherboard Replacement: step 5, image 1 of 2 Lenovo 500e Chromebook 81ES Motherboard Replacement: step 5, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the four 4 mm-long screws that secure the battery.
      Ask FixBot
    4. Lenovo 500e Chromebook 81ES Motherboard Replacement: step 6, image 1 of 2 Lenovo 500e Chromebook 81ES Motherboard Replacement: step 6, image 2 of 2
      • Slide a spudger under the battery.
      • Slightly lift the battery with the spudger, then grip and remove the battery.
      • If the battery appears bulging or has any visible bubbles, proceed with extreme caution during removal.
      Ask FixBot
    1. Lenovo 500e Chromebook 81ES Motherboard Replacement, Motherboard: step 7, image 1 of 2 Lenovo 500e Chromebook 81ES Motherboard Replacement, Motherboard: step 7, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the four 2 mm-long screws that secure the metal bracket over the ports.
      Ask FixBot
    2. Lenovo 500e Chromebook 81ES Motherboard Replacement: step 8, image 1 of 1
      • Remove the metal bracket.
      Ask FixBot
    3. Lenovo 500e Chromebook 81ES Motherboard Replacement: step 9, image 1 of 1
      • Using a spudger to carefully lift up the gates connecting the ribbon cables to the motherboard.
      • Disconnect the ribbon cables.
      Ask FixBot
    4. Lenovo 500e Chromebook 81ES Motherboard Replacement: step 10, image 1 of 1
      • Use tweezers to disconnect the speaker cable.
      Ask FixBot
    5. Lenovo 500e Chromebook 81ES Motherboard Replacement: step 11, image 1 of 1
      • Use a Phillips #0 screwdriver remove the six screws securing the motherboard.
      Ask FixBot
    6. Lenovo 500e Chromebook 81ES Motherboard Replacement: step 12, image 1 of 1
      • Use tweezers to disconnect the connector.
      Ask FixBot
    7. Lenovo 500e Chromebook 81ES Motherboard Replacement: step 13, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the single screw securing the Wi-Fi Card.
      Ask FixBot
    8. Lenovo 500e Chromebook 81ES Motherboard Replacement: step 14, image 1 of 1
      • Remove the Wi-Fi card.
      Ask FixBot
    9. Lenovo 500e Chromebook 81ES Motherboard Replacement: step 15, image 1 of 1
      • Remove the motherboard.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Nick
385 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 58
All Time: 293
