Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide
View statistics:
Past 24 Hours:
0
Past 7 Days:
22
Past 30 Days:
64
All Time:
347
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will help you replace the screen in the Lenovo 500e Chromebook 81ES. If you are experiencing issues with the cracks, including a physical damage, color distortion, flickering, follow this guide. For this guide, you will need a spudger,  Phillips #0 screwdriver, opening picks and tweezers. Make sure the Chromebook is powered off and unplugged from the charger.
Tools
    1. Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide, Lower Case: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the ten 4 mm-long screws that secure the lower case.
      Ask FixBot
    2. Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 2, image 1 of 2 Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 2, image 2 of 2
      • Insert the flat end of a spudger into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide, Display Assembly: step 3, image 1 of 3 Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide, Display Assembly: step 3, image 2 of 3 Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide, Display Assembly: step 3, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the six 5 mm-long screws securing the two hinges.
      • Use tweezers to lift up the hinges.
      • Using a spudger, gently disconnect the display connector.
      Ask FixBot
    2. Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 4, image 1 of 2 Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 4, image 2 of 2
      • Remove the single Phillips screw securing the Wi-Fi card.
      Ask FixBot
    3. Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 5, image 1 of 1
      • Disconnect the Wi-Fi card.
      Ask FixBot
    4. Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 6, image 1 of 3 Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 6, image 2 of 3 Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 6, image 3 of 3
      • Remove the display assembly.
      • Insert the opening picks and spudger into the screen casing.
      • Remove the screen.
      Ask FixBot
    5. Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 7, image 1 of 3 Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 7, image 2 of 3 Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 7, image 3 of 3
      • Slide the spudger into the center control cover.
      • Using tweezers, remove the cover.
      Ask FixBot
    6. Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 8, image 1 of 2 Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 8, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the three 2 mm-long screws securing the screen.
      Ask FixBot
    7. Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 9, image 1 of 3 Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 9, image 2 of 3 Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 9, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the three 3 mm-long screws on the top holding the display hinge metal bracket.
      • Use a Phillips #0 screwdriver to remove the two 2 mm-long screws on the bottom of the metal bracket.
      Ask FixBot
    8. Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 10, image 1 of 2 Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 10, image 2 of 2
      • Use tweezers to remove the metal bracket.
      • Using tweezers, gently pull the main cables attached to the sensor board.
      Ask FixBot
    9. Lenovo 500e Chromebook 81ES Display Assembly Replacement Guide: step 11, image 1 of 1
      • The screen is detached from the laptop.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 64
All Time: 347
