Lenovo 500e Chromebook 81ES Camera Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
56
All Time:
219
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 55 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will help you replace the camera in a Lenovo 500e Chromebook 81ES. If you are experiencing issues with damaged lens, cracked casing, no image, follow this guide. For this guide, you will need a spudger,  Phillips #0 screwdriver, tweezers and opening picks. Make sure the Chromebook is powered off and unplugged from the charger.
Parts
Tools
    1. Lenovo 500e Chromebook 81ES Camera Replacement, Display Assembly: step 1, image 1 of 3 Lenovo 500e Chromebook 81ES Camera Replacement, Display Assembly: step 1, image 2 of 3 Lenovo 500e Chromebook 81ES Camera Replacement, Display Assembly: step 1, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the six 5 mm-long screws securing the two hinges.
      • Use tweezers to lift up the hinges.
      • Using a spudger, gently disconnect the display connector.
      Ask FixBot
    2. Lenovo 500e Chromebook 81ES Camera Replacement: step 2, image 1 of 2 Lenovo 500e Chromebook 81ES Camera Replacement: step 2, image 2 of 2
      • Remove the single Phillips screw securing the Wi-Fi card.
      Ask FixBot
    3. Lenovo 500e Chromebook 81ES Camera Replacement: step 3, image 1 of 1
      • Disconnect the Wi-Fi card.
      Ask FixBot
    4. Lenovo 500e Chromebook 81ES Camera Replacement: step 4, image 1 of 3 Lenovo 500e Chromebook 81ES Camera Replacement: step 4, image 2 of 3 Lenovo 500e Chromebook 81ES Camera Replacement: step 4, image 3 of 3
      • Remove the display assembly.
      • Insert the opening picks and spudger into the screen casing.
      • Remove the screen.
      Ask FixBot
    5. Lenovo 500e Chromebook 81ES Camera Replacement: step 5, image 1 of 3 Lenovo 500e Chromebook 81ES Camera Replacement: step 5, image 2 of 3 Lenovo 500e Chromebook 81ES Camera Replacement: step 5, image 3 of 3
      • Slide the spudger into the center control cover.
      • Using tweezers, remove the cover.
      Ask FixBot
    6. Lenovo 500e Chromebook 81ES Camera Replacement: step 6, image 1 of 2 Lenovo 500e Chromebook 81ES Camera Replacement: step 6, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the three 2 mm-long screws securing the screen.
      Ask FixBot
    7. Lenovo 500e Chromebook 81ES Camera Replacement: step 7, image 1 of 3 Lenovo 500e Chromebook 81ES Camera Replacement: step 7, image 2 of 3 Lenovo 500e Chromebook 81ES Camera Replacement: step 7, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the three 3 mm-long screws on the top holding the display hinge metal bracket.
      • Use a Phillips #0 screwdriver to remove the two 2 mm-long screws on the bottom of the metal bracket.
      Ask FixBot
    8. Lenovo 500e Chromebook 81ES Camera Replacement: step 8, image 1 of 2 Lenovo 500e Chromebook 81ES Camera Replacement: step 8, image 2 of 2
      • Use tweezers to remove the metal bracket.
      • Using tweezers, gently pull the main cables attached to the sensor board.
      Ask FixBot
    9. Lenovo 500e Chromebook 81ES Camera Replacement: step 9, image 1 of 1
      • The screen is detached from the laptop.
      Ask FixBot
    1. Lenovo 500e Chromebook 81ES Camera Replacement, Camera: step 10, image 1 of 2 Lenovo 500e Chromebook 81ES Camera Replacement, Camera: step 10, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the four 3 mm screws from the camera bracket.
      Ask FixBot
    2. Lenovo 500e Chromebook 81ES Camera Replacement: step 11, image 1 of 2 Lenovo 500e Chromebook 81ES Camera Replacement: step 11, image 2 of 2
      • Use the Tweezers to remove the bracket from the back of the screen.
      Ask FixBot
    3. Lenovo 500e Chromebook 81ES Camera Replacement: step 12, image 1 of 2 Lenovo 500e Chromebook 81ES Camera Replacement: step 12, image 2 of 2
      • Now use the Tweezers to gently remove the cable connected to the camera.
      Ask FixBot
    4. Lenovo 500e Chromebook 81ES Camera Replacement: step 13, image 1 of 2 Lenovo 500e Chromebook 81ES Camera Replacement: step 13, image 2 of 2
      • Now use the tweezers to remove the camera.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 56
All Time: 219
