Introduction
This guide will help you with the replacement of a battery in the Lenovo 500e Chromebook 81ES. If you are experiencing issues with the battery, including a dead battery or bad connections, follow this guide. For this guide, you will need a Spudger, Phillips #0 screwdriver, and tweezers. Make sure the Chromebook is powered off and unplug it from the charger.
Use a Phillips #0 screwdriver to remove the ten 4 mm-long screws that secure the lower case.
Use a spudger to flip up the locking flap securing the lower I/O board ribbon cable to the motherboard.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
