Shop the Holiday Gift Guide
Lenovo 14e Chromebook Speakers Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
47
All Time:
222
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
    1. Lenovo 14e Chromebook Speakers Replacement, Battery: step 1, image 1 of 2 Lenovo 14e Chromebook Speakers Replacement, Battery: step 1, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the nine 8.6 mm screws from the back cover.
      Ask FixBot
    2. Lenovo 14e Chromebook Speakers Replacement: step 2, image 1 of 2 Lenovo 14e Chromebook Speakers Replacement: step 2, image 2 of 2
      • Carefully remove the back cover from the Chromebook.
      • You may hear clicking sounds as the cover becomes detached from the frame.
      Ask FixBot
    3. Lenovo 14e Chromebook Speakers Replacement: step 3, image 1 of 2 Lenovo 14e Chromebook Speakers Replacement: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the four 5.5 mm screws holding the battery in place.
      • Do not apply too much downward pressure when unscrewing the screws, as the interior contains many vital and fragile components.
      Ask FixBot
    4. Lenovo 14e Chromebook Speakers Replacement: step 4, image 1 of 2 Lenovo 14e Chromebook Speakers Replacement: step 4, image 2 of 2
      • Gently disconnect the power interface using a pair of tweezers.
      • Lift the battery out of the Chromebook.
      Ask FixBot
    1. Lenovo 14e Chromebook Speakers Replacement, Daughterboard: step 5, image 1 of 2 Lenovo 14e Chromebook Speakers Replacement, Daughterboard: step 5, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the three screws from the daughterboard bracket.
      • Remove the bracket.
      Ask FixBot
    2. Lenovo 14e Chromebook Speakers Replacement: step 6, image 1 of 2 Lenovo 14e Chromebook Speakers Replacement: step 6, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the two screws from the daughterboard.
      Ask FixBot
    3. Lenovo 14e Chromebook Speakers Replacement: step 7, image 1 of 2 Lenovo 14e Chromebook Speakers Replacement: step 7, image 2 of 2
      • Detach the two ribbon cables from the daughterboard and remove it from the laptop.
      Ask FixBot
    1. Lenovo 14e Chromebook Speakers Replacement, Speakers: step 8, image 1 of 1
      • Detach the white speaker cable connector from the bottom of the motherboard.
      Ask FixBot
    2. Lenovo 14e Chromebook Speakers Replacement: step 9, image 1 of 1
      • Remove the left speaker in order to access and remove the wire.
      Ask FixBot
    3. Lenovo 14e Chromebook Speakers Replacement: step 10, image 1 of 2 Lenovo 14e Chromebook Speakers Replacement: step 10, image 2 of 2
      • Remove the tape keeping the wire in place.
      Ask FixBot
    4. Lenovo 14e Chromebook Speakers Replacement: step 11, image 1 of 1
      • Remove the speakers and connecting wire from the laptop.
      Ask FixBot
Kristen Gismondi
110,159 Reputation
271 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 47
All Time: 222
