Shop the Holiday Gift Guide
Lenovo 14e Chromebook Palm Rest Assembly Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
62
All Time:
380
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
Are you having issues with your Lenovo 14e Chromebook keyboard being slow, unresponsive, or just not functioning as intended? In this guide you will find the steps on how to replace the palm rest assembly, which includes the keyboard.
It is recommended you visit the designated troubleshooting page for this part first to ensure that a keyboard replacement is necessary.
Before beginning the steps in this guide, ensure the Chromebook is powered off and unplugged from any devices.
Tools
    1. Lenovo 14e Chromebook Palm Rest Assembly Replacement, Battery: step 1, image 1 of 2 Lenovo 14e Chromebook Palm Rest Assembly Replacement, Battery: step 1, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the nine 8.6 mm screws from the back cover.
      Ask FixBot
    2. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 2, image 1 of 2 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 2, image 2 of 2
      • Carefully remove the back cover from the Chromebook.
      • You may hear clicking sounds as the cover becomes detached from the frame.
      Ask FixBot
    3. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 3, image 1 of 2 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the four 5.5 mm screws holding the battery in place.
      • Do not apply too much downward pressure when unscrewing the screws, as the interior contains many vital and fragile components.
      Ask FixBot
    4. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 4, image 1 of 2 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 4, image 2 of 2
      • Gently disconnect the power interface using a pair of tweezers.
      • Lift the battery out of the Chromebook.
      Ask FixBot
    1. Lenovo 14e Chromebook Palm Rest Assembly Replacement, Motherboard: step 5, image 1 of 2 Lenovo 14e Chromebook Palm Rest Assembly Replacement, Motherboard: step 5, image 2 of 2
      • Disconnect the display cable from the top of the motherboard.
      • Detach the white speaker cable connector from the bottom of the motherboard.
      Ask FixBot
    2. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 6, image 1 of 3 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 6, image 2 of 3 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 6, image 3 of 3
      • Grasp the KB strip and disconnect it.
      Ask FixBot
    3. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 7, image 1 of 3 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 7, image 2 of 3 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 7, image 3 of 3
      • DIsconnect the three MB strips.
      Ask FixBot
    4. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 8, image 1 of 2 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 8, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the 5.5mm screw holding the WLAN card in place.
      • Disconnect the two wires from the WLAN card.
      • Remove the WLAN card.
      Ask FixBot
    5. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 9, image 1 of 2 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 9, image 2 of 2
      • Remove the 8.3 mm screw holding the bracket in place using a Phillips #0 screwdriver.
      • Remove the bracket.
      Ask FixBot
    6. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 10, image 1 of 2 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 10, image 2 of 2
      • Remove the black 5.5 mm screw in the top right hinge using a Phillips #0 screwdriver.
      • Pull the hinge up.
      Ask FixBot
    7. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 11, image 1 of 2 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 11, image 2 of 2
      • Remove the 5.5mm screws surrounding the motherboard using a Phillips #0 screwdriver.
      Ask FixBot
    8. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 12, image 1 of 1
      • Carefully remove the motherboard.
      Ask FixBot
    1. Lenovo 14e Chromebook Palm Rest Assembly Replacement, Daughterboard: step 13, image 1 of 2 Lenovo 14e Chromebook Palm Rest Assembly Replacement, Daughterboard: step 13, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the three screws from the daughterboard bracket.
      Ask FixBot
    2. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 14, image 1 of 2 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 14, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the two screws from the daughterboard.
      Ask FixBot
    3. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 15, image 1 of 2 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 15, image 2 of 2
      • Detach the two ribbon cables from the daughterboard and remove it from the laptop.
      Ask FixBot
    1. Lenovo 14e Chromebook Palm Rest Assembly Replacement, Palm Rest Assembly: step 16, image 1 of 1
      • Remove the surrounding audio frame in order to access and remove the wire.
      Ask FixBot
    2. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 17, image 1 of 2 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 17, image 2 of 2
      • Remove the tape keeping the wire in place.
      Ask FixBot
    3. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 18, image 1 of 1
      • Carefully remove the audio frames and the connecting red wire from the Chromebook.
      Ask FixBot
    4. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 19, image 1 of 1
      • Gently remove the connecting keyboard wire.
      Ask FixBot
    5. Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 20, image 1 of 3 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 20, image 2 of 3 Lenovo 14e Chromebook Palm Rest Assembly Replacement: step 20, image 3 of 3
      • Separate the palm rest assembly from the screen.
      • Repeat on the other side.
      Ask FixBot
Author
with
Jordan Ortiz
121 Reputation
1 Guide authored
Texas Tech, Team 2-4, Johansen Fall 2025 Member of Texas Tech, Team 2-4, Johansen Fall 2025
TTU-JOHANSEN-F25S2G4
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 62
All Time: 380
