Shop the Holiday Gift Guide
Lenovo 14e Chromebook Motherboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
78
All Time:
449
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Lenovo 14e Chromebook motherboard is facing issues, this guide will help you replace it! This process involves disconnection of multiple internal components, so make sure to have a clean, clutter-free surface to work on. We recommend taking a look at the Troubleshooting Guide before you get started to assess if there are minor issues causing the problem before replacing the entire part.
Before moving forward, make sure you have all the listed tools, your chromebook is powered off, and unplugged.
Parts
Tools
    1. Lenovo 14e Chromebook Motherboard Replacement, Battery: step 1, image 1 of 2 Lenovo 14e Chromebook Motherboard Replacement, Battery: step 1, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the nine 8.6 mm screws from the back cover.
      Ask FixBot
    2. Lenovo 14e Chromebook Motherboard Replacement: step 2, image 1 of 2 Lenovo 14e Chromebook Motherboard Replacement: step 2, image 2 of 2
      • Carefully remove the back cover from the Chromebook.
      • You may hear clicking sounds as the cover becomes detached from the frame.
      Ask FixBot
    3. Lenovo 14e Chromebook Motherboard Replacement: step 3, image 1 of 2 Lenovo 14e Chromebook Motherboard Replacement: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the four 5.5 mm screws holding the battery in place.
      • Do not apply too much downward pressure when unscrewing the screws, as the interior contains many vital and fragile components.
      Ask FixBot
    4. Lenovo 14e Chromebook Motherboard Replacement: step 4, image 1 of 2 Lenovo 14e Chromebook Motherboard Replacement: step 4, image 2 of 2
      • Gently disconnect the power interface using a pair of tweezers.
      • Lift the battery out of the Chromebook.
      Ask FixBot
    1. Lenovo 14e Chromebook Motherboard Replacement, Motherboard: step 5, image 1 of 2 Lenovo 14e Chromebook Motherboard Replacement, Motherboard: step 5, image 2 of 2
      • Disconnect the display cable from the top of the motherboard.
      • Detach the white speaker cable connector from the bottom of the motherboard.
      Ask FixBot
    2. Lenovo 14e Chromebook Motherboard Replacement: step 6, image 1 of 3 Lenovo 14e Chromebook Motherboard Replacement: step 6, image 2 of 3 Lenovo 14e Chromebook Motherboard Replacement: step 6, image 3 of 3
      • Grasp the KB strip and disconnect it.
      Ask FixBot
    3. Lenovo 14e Chromebook Motherboard Replacement: step 7, image 1 of 3 Lenovo 14e Chromebook Motherboard Replacement: step 7, image 2 of 3 Lenovo 14e Chromebook Motherboard Replacement: step 7, image 3 of 3
      • DIsconnect the three MB strips.
      Ask FixBot
    4. Lenovo 14e Chromebook Motherboard Replacement: step 8, image 1 of 2 Lenovo 14e Chromebook Motherboard Replacement: step 8, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the 5.5mm screw holding the WLAN card in place.
      • Disconnect the two wires from the WLAN card.
      • Remove the WLAN card.
      Ask FixBot
    5. Lenovo 14e Chromebook Motherboard Replacement: step 9, image 1 of 2 Lenovo 14e Chromebook Motherboard Replacement: step 9, image 2 of 2
      • Remove the 8.3 mm screw holding the bracket in place using a Phillips #0 screwdriver.
      • Remove the bracket.
      Ask FixBot
    6. Lenovo 14e Chromebook Motherboard Replacement: step 10, image 1 of 2 Lenovo 14e Chromebook Motherboard Replacement: step 10, image 2 of 2
      • Remove the black 5.5 mm screw in the top right hinge using a Phillips #0 screwdriver.
      • Pull the hinge up.
      Ask FixBot
    7. Lenovo 14e Chromebook Motherboard Replacement: step 11, image 1 of 2 Lenovo 14e Chromebook Motherboard Replacement: step 11, image 2 of 2
      • Remove the 5.5mm screws surrounding the motherboard using a Phillips #0 screwdriver.
      Ask FixBot
    8. Lenovo 14e Chromebook Motherboard Replacement: step 12, image 1 of 1
      • Carefully remove the motherboard.
      Ask FixBot
To reassemble your device, carefully follow these instructions in reverse order.
Author
with
Katelyn Fielder
157 Reputation
1 Guide authored
Texas Tech, Team 2-4, Johansen Fall 2025 Member of Texas Tech, Team 2-4, Johansen Fall 2025
TTU-JOHANSEN-F25S2G4
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 78
All Time: 449
