Lenovo 100s Chromebook-11IBY Webcam Replacement
  1. Lenovo 100s Chromebook-11IBY Webcam Replacement, Webcam: step 1, image 1 of 1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Webcam Replacement: step 2, image 1 of 1
    • Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
  3. Lenovo 100s Chromebook-11IBY Webcam Replacement: step 3, image 1 of 2 Lenovo 100s Chromebook-11IBY Webcam Replacement: step 3, image 2 of 2
    • Carefully pry up and underneath both the (left & right) hinges of the screen cover.
  4. Lenovo 100s Chromebook-11IBY Webcam Replacement: step 4, image 1 of 2 Lenovo 100s Chromebook-11IBY Webcam Replacement: step 4, image 2 of 2
    • Use the plastic opening tool on the inside of the screen plate and again on the sides to gently remove it.
  5. Lenovo 100s Chromebook-11IBY Webcam Replacement: step 5, image 1 of 1
    • Gently unplug the wire connecting the webcam to the laptop.
  6. Lenovo 100s Chromebook-11IBY Webcam Replacement: step 6, image 1 of 2 Lenovo 100s Chromebook-11IBY Webcam Replacement: step 6, image 2 of 2
    • Using the plastic opening tool, gently lift the webcam panel from the screen. Then remove it.
Milton Perez
630 Reputation
5 Guides authored
USF Tampa, Team S7-G2, Cagle Spring 2017 Member of USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Member
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 322
