Community-Contributed Guide
Introduction
Go to step 1 ↓Before You Begin:
- Remove the battery and film from the camera.
- Consider recording the entire repair process with a phone or video camera.
Important Notes:
- Do not use excessive force when disassembling parts.
- Avoid touching the circuit board, especially the flash capacitor, as it may retain a high voltage charge. Consider wearing gloves for added protection.
Your Contribution is Welcome:
If you have any suggestions for improving this guide, such as correcting errors or suggesting clearer language, please feel free to share your feedback. Thank you!
Unscrew: Remove the 4 screws on the bottom case and the single screw on the back near the viewfinder.
Unscrew the 4 screws around the lens protection cover, and then remove the lens protection cover.
Add some marks on the ring for later reinstallation(This step is unnecessary if the lens barrel and other structures remain unchanged).
Use one finger to cover the rectangular area to prevent the spring from flying away. Then, remove the spring.
Remove the focus gear.
Unscrew 4 screws, remove film guide
Unscrew 2 screws, remove light and FPC contact shade
Unscrew the 6 screws to detach the lens module. You can remove the lens module now or later.
Unsolder the FPC joints.
Unscrew the 4 screws securing the rear lens guide. Carefully remove the guide, making sure not to lose the spring that connects the three(or two) pieces. Keep these pieces together.
Locate the two contact points on the rear lens rings. You may need a special tool('井') to loosen these points, such as a small screwdriver or tweezers may be okay too(I haven't tried).
Remove the lens barrel, ensuring that the other two barrels remain in their original positions. Misaligning these barrels can be difficult to correct.
Desolder the existing FPC, paying special attention to the two chips marked with circles, ensuring they both maintain their original orientation. Carefully desolder these chips and transfer them to the new FPC.
Unscrew 1 screw on FPC, unsolder 4 joints of relays.
Unscrew 3 screws.
Unscrew 1 screw on FPC, unsolder 4 joints of optocoupler. Be aware the ring and ring position points by arrows. It's easy to fall off, so I keep it as the last step, after completely remove FPC, install the new one immediately.
There are some plastic pads stick on old FPC, remove and install them on the new FPC.
See these images for install Shutter and Aperture movement part back.
First screw rare element group and shutter module together.
Align the center of the shutter FPC with the notch on the front of the lens barrel. Gently push the lens module back into place. You may hear a click as the rear module locks into position. Slightly rotate the rear module to ensure it's securely locked.
With help of Gemini from Google.
3 Guide Comments
hello !!! i have a question. i dont haave a flex cable problem but a lens cover problem. i onlyy needed to be in step 4 and here i have a question. there is too much friction with this cover between the black plastic piece and the camera cover: do you know, apartt from adjusting the metal piece, if this piece needs any product so it slides easier ?
Hello,
I am Red Dot Repair, I run the Minilux repair service. I've been professionally offering this repair for 7 years.
I must warn you of trying this repair yourself, not just the flex cable but also the lens cover.
This is not an issue with friction, having to lubricate, or the flex cable. This is either a broken switch, or an assembly error. There is a special procedure and order of operations that needs to be followed in order to properly reassemble this camera so the lens door can operate freely.
If done incorrectly, two very critical failures may happen. A fragile plastic post inside of the camera will break, effectively bricking the camera, or a switch inside will get caught and break. I have had too many clients follow this guide only to damage their cameras.
Full conflict of interest aside, since I do offer this repair at my shop, but out of my personal love for the Minilux I must warn others about this guide. It is extremely misleading and leaves out critical details.
