Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
The top cover, clear circular part, and L-shaped parts sit above the electronics. These parts will need to be removed in order to expose the electronics for replacement.
Parts
No parts specified.
  1. Be careful not to crack the cover. Use the metal spudger to gently pry open the corners of the top cover.
    • Be careful not to crack the cover.
    • Use the metal spudger to gently pry open the corners of the top cover.
  2. Be careful not to crack the top cover.
    • Be careful not to crack the top cover.
    • Use the metal spudger to gently pry up the center of the top cover.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Pull the top cover off.
    • Pull the top cover off.
  5. Lift up the circular illumination stand and remove it from the toy pad.
    • Lift up the circular illumination stand and remove it from the toy pad.
  6. Lift up the white L-shaped pieces and remove them from the toy pad.
    • Lift up the white L-shaped pieces and remove them from the toy pad.
Alyssa Lach
428 Reputation
4 Guides authored
IUPUI, Team S5-G2, Baechle Fall 2017 Member of IUPUI, Team S5-G2, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G2
2 Members
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 224
