Introduction
The cable on the Ledlenser H8R headlamp was torn off?[
No problem, you can solder it back on
Unscrew 2 screws, you need a Torx T6 for this
then remove the white part
do not touch the LED!
Riddle: which wire goes where?
red = D+ / black = D-
green = VSS / yellow = SW (= switch)
white = NTC (= temperature sensor)
To be on the safe side, remove the battery from the battery compartment
Attention, before soldering don't forget:
Thread the cable through the two housings
Thread the cable through the kink protection
Solder 5 times
Secure cable with cable tie
Now you can test, but please only briefly, otherwise the LED will get too hot
Assemble the lamp!
Follow these steps in reverse order to reassemble your device
Special thanks to these translators:
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
