Introduction
This guide will show you the most basic of seams, the straight seam. If this is your first sewing experience, practice on scraps of fabric. Like any skill, sewing requires practice—so take your time! The key is to work carefully and patiently. Sewing machines vary widely and may have different settings. This guide shows the process for a Bernina 830, but the process will be similar for most machines. Refer to your sewing machine manual for information on specific settings and functions. In this guide we are using contrasting thread for visibility. When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
Lay the two pieces of fabric with the right sides together. Align the edges you would like to sew. Push out all the wrinkles and smooth the fabric flat.
Starting at one end of the seam, match the corners and pin them together.
Make sure the settings on your sewing machine are set to sew a straight stitch.
Slide the corner of your fabric into the sewing machine, directly under the hole in the presser foot.
Align the edge of your fabric with the edge of the pressor foot.
Lower the presser foot using the presser foot lever.
Use the balance wheel (also know as the hand wheel) to advance the sewing machine until the needle has sunk into the fabric.
Engage your backstitch function.
Depress the pedal slowly. This will start the sewing machine sewing backwards.
Sew two or three stitches backwards.
Release the pedal.
Release your backstitch function.
Pull the fabric out of the sewing machine.
Clip the threads as close to the fabric as possible.
Turn your seam right side out, and admire your work.
Thank you! A well written and good visual tutorial. I'm getting ready to make my nieces pretty headbands for the summer.
I've designed them myself. Making the pattern, I've already cut the pieces out. I was slightly reluctant to begin, because I
worried about the fabric shifting. Thanks to your tutorial I have the understanding & confidence necessary to complete my project!
9 other people completed this guide.
2 Comments
Thank You!!! This helped me so much <3
I really mean it! Thank You! ʕ•ᴥ•ʔ
Es empfiehlt sich, den Stoff vor dem Nähen zu bügeln. Falten werden so vermieden und der Stoff lässt sich besser führen und heften. Dadurch wird das Ergebnis besser.
Eva - Reply
