Introduction
A damaged screen inhibits view and touchscreen functionality of the device. A screen replacement is necessary when the damage to the screen prevents the device from being used to its maximum capacity. When following this guide, be careful not to cause harm to any of the other internal components as they are very fragile.
Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
My device had the 7mm screw to the right of the cartridge slot and the 2 to the left of the cartridge slot were also 7mm.
the other 9 were indeed 8mm,
Mike.
Disconnect the battery using tweezers or your fingernails.
The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
Gently pry of the battery lose using a spudger or another thin prying tool.
This was extremely helpful, and easy to do!! Thank you so much! You saved the day!
Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically.
Remove the side grips simply pulling them both vertically exposing eight screws.
from where can I purchase a display? How is the price?
Does any one know from where I can purchase a display?
10 other people completed this guide.
8 Comments
Where would i purchase the new screen?
I bought mine on eBay for 15.00.
Could you send the link to where you bought yours
