Introduction
This replacement guide will teach you how to remove and replace the back facing camera to your Leader Impression i10A-LE tablet. This fix can take anywhere from 15-25 minutes.
Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
Start by prying the back off by using plastic opening tools.
Using the plastic tools slide the flat end into the device.
Gently pry the back piece until you hear a popping noise.
Once the back is loose, remove it from the device and set aside.
Once the back is off, locate the back facing camera.
The camera will be in the top left corner.
Using the precision tweezers that are bent, gently grab the strip below the camera.
slowly lift up until the camera lifts from its spot.
Continue slowly lifting with the bent precision tweezers.
The bottom half of the camera strip will pop out.
