Le Pavé Parisien V1: Replacing the loudspeaker
  1. Le Pavé Parisien V1: Replacing the loudspeaker, Remove the grill: step 1, image 1 of 2 Le Pavé Parisien V1: Replacing the loudspeaker, Remove the grill: step 1, image 2 of 2
    • Remove the speaker protective grill by first lifting one corner.
  2. Le Pavé Parisien V1: Replacing the loudspeaker, Unscrew the loudspeaker: step 2, image 1 of 2 Le Pavé Parisien V1: Replacing the loudspeaker, Unscrew the loudspeaker: step 2, image 2 of 2
    • Remove the 4 speaker retaining screws using an M4 allen wrench.
  3. Le Pavé Parisien V1: Replacing the loudspeaker, Disconnecting the loudspeaker: step 3, image 1 of 2 Le Pavé Parisien V1: Replacing the loudspeaker, Disconnecting the loudspeaker: step 3, image 2 of 2
    • Lift the speaker out of the concrete shell in order to access the connections.
    • To disconnect the speker, pull each of the cables, gripping the connector and easing it from side to side.
    • You only have to connect the replacement speaker and follow the instructions in reverse in order to reassemble your Pavé Parisien.
  4. Le Pavé Parisien V1: Replacing the loudspeaker, Replacing the speaker in the shell: step 4, image 1 of 2 Le Pavé Parisien V1: Replacing the loudspeaker, Replacing the speaker in the shell: step 4, image 2 of 2
    • Connect the speaker as in step 3. Take care to ensure the connectors are on the side where there is a notch in the concrete.
  5. Le Pavé Parisien V1: Replacing the loudspeaker, Finish: step 5, image 1 of 1
    • You only have to replace the screws and the protective grill and your Pavé Parisien is reassembled!
Follow these instruction in reverse order to reassemble your device.
Special thanks to these translators:
fr en
100%
Philip Le Riche is helping us fix the world! Want to contribute?
Start translating ›
Le Pavé Parisien
529 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 58
