The Pave Parisien Speaker: Battery replacement
  1. The Pave Parisien Speaker: Battery replacement, Remove the grille: step 1, image 1 of 2 The Pave Parisien Speaker: Battery replacement, Remove the grille: step 1, image 2 of 2
    • Remove the protective grille by lifting one of the four corners.
  2. The Pave Parisien Speaker: Battery replacement, Opening the speaker: step 2, image 1 of 2 The Pave Parisien Speaker: Battery replacement, Opening the speaker: step 2, image 2 of 2
    • Remove the four screws using a m4 allen wrench
  3. The Pave Parisien Speaker: Battery replacement, Disconnecting the speaker: step 3, image 1 of 2 The Pave Parisien Speaker: Battery replacement, Disconnecting the speaker: step 3, image 2 of 2
    • Pull the speaker out a bit to access the connectors
    • With light gentle movements, pull and disconnect the two cables from the connections
  4. The Pave Parisien Speaker: Battery replacement, Pulling the board out of the case: step 4, image 1 of 2 The Pave Parisien Speaker: Battery replacement, Pulling the board out of the case: step 4, image 2 of 2
    • Pull the speaker completely out of the recessed compartment
    • Gently pull the board behind the speaker out and place on a flat surface
  5. The Pave Parisien Speaker: Battery replacement, Disconnecting the battery: step 5, image 1 of 3 The Pave Parisien Speaker: Battery replacement, Disconnecting the battery: step 5, image 2 of 3 The Pave Parisien Speaker: Battery replacement, Disconnecting the battery: step 5, image 3 of 3
    • Disconnect the battery connector from the board
    • Be careful to pull gently using a small screwdriver to pry up the clip, then apply gentle pressure
  6. The Pave Parisien Speaker: Battery replacement, Removing the battery: step 6, image 1 of 2 The Pave Parisien Speaker: Battery replacement, Removing the battery: step 6, image 2 of 2
    • Push the battery from the rear towards the opening where the wires are
    • The battery is out and now it can be changed
  7. The Pave Parisien Speaker: Battery replacement, Connecting the new battery: step 7, image 1 of 3 The Pave Parisien Speaker: Battery replacement, Connecting the new battery: step 7, image 2 of 3 The Pave Parisien Speaker: Battery replacement, Connecting the new battery: step 7, image 3 of 3
    • Pass the connector through the space that is indicated for it
  8. The Pave Parisien Speaker: Battery replacement, Reinstalling the board: step 8, image 1 of 1
    • The texture of this surface is different from the other three faces. Orient yourself to how it fits correctly.
  9. The Pave Parisien Speaker: Battery replacement, Reinstalling the speaker: step 9, image 1 of 2 The Pave Parisien Speaker: Battery replacement, Reinstalling the speaker: step 9, image 2 of 2
    • First connect the positive and negative wires, then slide the speaker in the enclosure in the right orientation
  10. The Pave Parisien Speaker: Battery replacement, Finished: step 10, image 1 of 1
    • Finally replace the speaker grill: your Pave Parisien is ready to use!
Finish Line
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Le Pavé Parisien
529 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 136
