Le Pan S Battery Replacement
  1. Le Pan S Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
    • This cover is adjacent to the volume button on the side of the Le Pan S.
  2. Le Pan S Battery Replacement: step 2, image 1 of 2 Le Pan S Battery Replacement: step 2, image 2 of 2
    • Insert the spudger between the front and back panel in order to pry them apart.
    • Do this beside the volume button and the micro SD cover.
    • Pry open the rest of the Le Pan S by dragging the spudger across the side.
  3. Le Pan S Battery Replacement: step 3, image 1 of 1
    • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
  4. Le Pan S Battery Replacement: step 4, image 1 of 2 Le Pan S Battery Replacement: step 4, image 2 of 2
    • Disconnect the battery from the circuitry and lay it out of the way.
    • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
    • If you are replacing your battery, make sure to dispose of it properly.
    What is the replacement battery to get? Model,type, anything would help..
    Bg70 - Reply
    what is a spudger? Where do you get it? Are replacement batteries still available somewhere?
    BETH SCHRECK - Reply
3 other people completed this guide.
Maria Dole
395 Reputation
3 Guides authored
IUPUI, Team 2-1, Harley Fall 2015 Member of IUPUI, Team 2-1, Harley Fall 2015
IUPUI-HARLEY-F15S2G1
5 Members
10 Guides authored
5 Comments
where can I purchase a battery for a tc978
Timothy - Reply
Hi Timothy, Did you ever find out where to purchase a battery for your Le Pan S tablet?
jatrussel -
But what do I do when it's not the battery, but is the charger is so loose in the tablet, it won;t charge. Once in a while, I can get it to come on if I happened to hold the charger just right. So disgusting. Can this be fixed.? i have purchased two LePans and neither will charge.
cdboers - Reply
Where can I purchase the battery needed?????????????????
jatrussel - Reply
Thank you Maria!
Easy to take apart. Disconnected/reconnected battery and voila!
All good.
Be well.
Den E
Denny Ehlers - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 5,372
