Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
The default values of the PS1 drives are between 940 - 970 ohms. To read burned CDs you have to go down a bit.
Warning ! Before you work on the open console, be sure to remove the power! Pull the plug!
Reducing the resistance, will increase the wear and tear of the laser ! If you go down in steps of ten and the CD is read correctly do not further reduce the value, that is useless.
CD's MUST be burned with a maximum burning speed of 4x, because the PS1 laser cannot deal with burn errors. If your burner only supports higher speeds, get another one, because then the games will most likely not work.
This Tweak is intended for 7000er consoles (750x, 700x)! Other PS1 consoles may have a bias & gain on the motherboard. If this value is adjusted then there are other instructions for it.
Video Instructions
Feedback and constructive criticism desired.
3 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
TheSupport
71 Reputation
1 Guide authored
One Comment
Swap to German ( ENGLISH TRANSLATION)
The default values ​​of the PS1 drives are between 940 - 970 ohms. To read burned CDs you have to go down a bit.Attention ! Before working on the open console, be sure to take the POWER away! Pull the plug!If you reduce the resistance value, the wear of the laser is increased! If you go down in steps of ten and the CD is read correctly does not reduce the value, that does not help.CD's MUST be burned with a maximum burning speed of 4x, because the PS1 laser with burn errors are not clear. If your burner only supports higher speeds, get another one, because then the games will most likely not work.This Tweak is for 7000er consoles intended (750x, 700x)! Other PS1 consoles may have a bias & gain on the motherboard. If this value is adjusted then there are other instructions for it.
Jordon Garcia - Reply
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 78
All Time: 1,477
