Cleaning The Lens
  1. Cleaning The Lens, Top Panel: step 1, image 1 of 2 Cleaning The Lens, Top Panel: step 1, image 2 of 2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
  2. Cleaning The Lens: step 2, image 1 of 2 Cleaning The Lens: step 2, image 2 of 2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Cleaning The Lens, Cleaning The Lens: step 3, image 1 of 2 Cleaning The Lens, Cleaning The Lens: step 3, image 2 of 2
    • Locate the lens on the disc drive.
    • Make sure that there is no dust on or near the player and area you are working on. Dust can get on the lens and scratch it while you are cleaning. It is very important that the lens is not damaged because the lens is used to read the discs.
    • Dip one end of a cotton swab in rubbing alcohol.
    • Lightly dab the swab on the lens. Be very gentle.
    • Let the lens dry before replacing the top plate of the DVD player.
Nathan Klammer
461 Reputation
3 Guides authored
Cal Poly, Team 21-20, Maness Fall 2011 Member of Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 Members
7 Guides authored
Past 24 Hours: 12
Past 7 Days: 69
Past 30 Days: 340
All Time: 48,297
