HP 15-bs015dx Teardown
Video Overview
  1. HP 15-bs015dx Teardown, Remove the Battery - Part 1: step 1, image 1 of 3 HP 15-bs015dx Teardown, Remove the Battery - Part 1: step 1, image 2 of 3 HP 15-bs015dx Teardown, Remove the Battery - Part 1: step 1, image 3 of 3
    • Put the laptop facing down
    • Move the left battery safe lock to the right
  2. HP 15-bs015dx Teardown, Remove the Battery - Part 2: step 2, image 1 of 3 HP 15-bs015dx Teardown, Remove the Battery - Part 2: step 2, image 2 of 3 HP 15-bs015dx Teardown, Remove the Battery - Part 2: step 2, image 3 of 3
    • Slide the right battery safe lock to the left
    • This lock is harder than the previous, with this the battery should pop-up.
  3. HP 15-bs015dx Teardown, Remove the 6 visibles screws: step 3, image 1 of 3 HP 15-bs015dx Teardown, Remove the 6 visibles screws: step 3, image 2 of 3 HP 15-bs015dx Teardown, Remove the 6 visibles screws: step 3, image 3 of 3
    • Use a Philips 0 screwdriver
  4. HP 15-bs015dx Teardown, Remove the 4 hidden screws: step 4, image 1 of 3 HP 15-bs015dx Teardown, Remove the 4 hidden screws: step 4, image 2 of 3 HP 15-bs015dx Teardown, Remove the 4 hidden screws: step 4, image 3 of 3
    • Use a straw to take off just enough of the rubber feet of the 4 corners
    • Use a Phillips screwdriver 0
    • Replace each rubber foot in place after removing the screws
    • You will have a total of 10 screws
  5. HP 15-bs015dx Teardown, Remove the DVD unit: step 5, image 1 of 2 HP 15-bs015dx Teardown, Remove the DVD unit: step 5, image 2 of 2
    • It will go out easily with or without a straw
    • You can check the model number
  6. HP 15-bs015dx Teardown, Separate the pieces of the chassis part 1: step 6, image 1 of 3 HP 15-bs015dx Teardown, Separate the pieces of the chassis part 1: step 6, image 2 of 3 HP 15-bs015dx Teardown, Separate the pieces of the chassis part 1: step 6, image 3 of 3
    • Flip the laptop and open it
    • Use a plastic tool or a straw to separate the pieces of the chassis
  7. HP 15-bs015dx Teardown, Separate the pieces of the chassis part 2: step 7, image 1 of 3 HP 15-bs015dx Teardown, Separate the pieces of the chassis part 2: step 7, image 2 of 3 HP 15-bs015dx Teardown, Separate the pieces of the chassis part 2: step 7, image 3 of 3
    • Flip the laptop and separate the inferior cover of the chassis
    • Hard Drive 2.5" SATA
    • 2 RAM memory slots type DDR4 SO-DIMM
    • CPU Intel 7th generation
    • Active heat sink (fan)
    • Wireless card
    • Watch battery, 3V. CR2030
39 other people completed this guide.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Marcos Mora
3,561 Reputation
11 Guides authored
16 Comments
Se me rompio las bisagras … como se reemplazan ?
Javier Horacio Monti - Reply
No tengo la laptop a mano para tomarle fotos, aunque en el paso 7 se puede ver algo. Depende de la rotura, lo típico que se rompe es la rosca para los tornillos, hay que crear un nueva rosca con material adicional, sin embargo, desconozco el procedimiento. En todo caso, puedes contactarme a mis RRSS que están en mi perfil de ifixit.
Marcos Mora -
Your step by step guide is apt. Thanks
Perebowei Titus Otoru Nigeria
Perebowei Titus Otoru - Reply
Buenas podrías hacer un tutorial desarmando y ensamblando la webcam
Javier - Reply
Saludos, ya entregué la laptop al cliente.
Marcos Mora -
Past 24 Hours: 50
Past 7 Days: 268
Past 30 Days: 1,200
All Time: 82,040
