Shop the Holiday Gift Guide
LOOKAH Unicorn Erig Battery Replacement Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
70
All Time:
654
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
How do you replace the battery on the Lookah Unicorn Erig?
The LOOKHA Unicorn is an electric dab rig.
It is sold at many head shops and vape shops. The batteries on the device will eventually wear out and need replacing. With a few tools such as a screwdriver and soldering iron, as well as replacement battery parts, you can replace the batteries in the base of the device fairly easily.
Here are the steps to open the device and replace the batteries. Please take care to source the correct size replacement batteries to ensure the device will work correctly after replacement.
Parts
Tools
    1. LOOKAH Unicorn Erig Battery Replacement Replacement, Remove the Glass Bubbler: step 1, image 1 of 1
      • Lift off the glass bubbler and magnetic ring and place them to one side.
      Ask FixBot
    2. LOOKAH Unicorn Erig Battery Replacement Replacement, Remove Non Slip Pads: step 2, image 1 of 1
      • Remove the three nonslip pads from the base of the unit.
      • This will expose three small crosshead (phillips) screws
      Ask FixBot
    3. LOOKAH Unicorn Erig Battery Replacement Replacement: step 3, image 1 of 1
      • Use a small screwdriver to remove the screws
      • Lift off the plastic base to show the battery and components
      Ask FixBot
    4. LOOKAH Unicorn Erig Battery Replacement Replacement, Remove the battery: step 4, image 1 of 3 LOOKAH Unicorn Erig Battery Replacement Replacement, Remove the battery: step 4, image 2 of 3 LOOKAH Unicorn Erig Battery Replacement Replacement, Remove the battery: step 4, image 3 of 3
      • Carefully lift out the batteries.
      • Remove the metal plate the batteries are stuck to
      • Remove the tape holding the batteries together
      Ask FixBot
    5. LOOKAH Unicorn Erig Battery Replacement Replacement, Unsolder batteries: step 5, image 1 of 3 LOOKAH Unicorn Erig Battery Replacement Replacement, Unsolder batteries: step 5, image 2 of 3 LOOKAH Unicorn Erig Battery Replacement Replacement, Unsolder batteries: step 5, image 3 of 3
      • Use a Solder Iron on to heat the solder and remove the cable from the batteries
      Ask FixBot
    6. LOOKAH Unicorn Erig Battery Replacement Replacement, Solder new batteries in place: step 6, image 1 of 2 LOOKAH Unicorn Erig Battery Replacement Replacement, Solder new batteries in place: step 6, image 2 of 2
      • Use a soldering iron to connect new battery.
      • Tape the two new batteries back together
      Ask FixBot
      • Click the power button five times to see if the device turns on
      Ask FixBot
    7. LOOKAH Unicorn Erig Battery Replacement Replacement: step 8, image 1 of 3 LOOKAH Unicorn Erig Battery Replacement Replacement: step 8, image 2 of 3 LOOKAH Unicorn Erig Battery Replacement Replacement: step 8, image 3 of 3
      • Replace the double-sided tape on the metal plate and connect it to batteries.
      • Reseat batteries and metal disc, with the metal disc side down into the unit's base. Note the orientation of the batteries. The base cover will not fit on if they are not the correct way around.
      • Line up the base cover and put it in place, with the plastic tab towards the USB port and the screws holes lined up
      Ask FixBot
    8. LOOKAH Unicorn Erig Battery Replacement Replacement, Screw base cover in place: step 9, image 1 of 2 LOOKAH Unicorn Erig Battery Replacement Replacement, Screw base cover in place: step 9, image 2 of 2
      • screw the base cover in place, taking care not to overtighten it.
      • Replace the non-slip pads.
      Ask FixBot
Author
with
James Mash
544 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 70
All Time: 654
