Turn over the phone so the front screen is facing down and the back side is up.
  • Turn over the phone so the front screen is facing down and the back side is up.
Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
  • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
  • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
  • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
  • Then press down on the bottom of the battery and it should snap into place
Michelle
17 Reputation
3 Guides authored
Cal Poly, Team 17-26, Amido Spring 2012 Member of Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 256
