LG VX6100 Front Case Replacement
  1. LG VX6100 Front Case Replacement, Front Case: step 1, image 1 of 1
    • Remove the four grey plugs using either tweezers or a push pin.
  2. LG VX6100 Front Case Replacement: step 2, image 1 of 1
    • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
    • Be sure to put the screws in a safe place as they are very small and easy to lose.
  3. LG VX6100 Front Case Replacement: step 3, image 1 of 1
    • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
    • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
    • Do this across the entire length of the seem until the case is no longer attached to the phone.
  4. LG VX6100 Front Case Replacement: step 4, image 1 of 1
    • The case can now be removed and the interior of the front is accessible.
Ryan Bishop
1 Reputation
3 Guides authored
Cal Poly, Team 12-39, Regan Spring 2012 Member of Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Members
16 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 764
