You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
This guide goes step-by-step through the process of removing the antenna. Each step in the guide is accompanied with clear pictures and instruction.
  1. Hold the phone upright and firmly twist the antenna counter-clockwise until it becomes loose. Once loose, pull upwards to remove the antenna from the phone.
    • Hold the phone upright and firmly twist the antenna counter-clockwise until it becomes loose. Once loose, pull upwards to remove the antenna from the phone.
Eric Funsten
1 Reputation
3 Guides authored
Cal Poly, Team 12-39, Regan Spring 2012 Member of Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Members
16 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 517
