Introduction
Use this guide to replace the battery in the LG V20.
If your battery is swollen be extra careful. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
Tools
No tools specified.
Parts
Press the button on the lower right side of the LG V20 to open the clamp that holds the back cover on the back side of the phone.
Remove the back cover.
Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
Be careful not to deform or puncture the battery.
Pry up and remove the battery.
For optimal performance and to avoid software sided errors, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
9 other people completed this guide.
3 Comments
Is this battery the same quality or a least pretty close to the OEM battery of the LG v20?
Don’t buy this battery. It looks like an OEM but it’s not. That’s fine but I’ve had this for a couple months and it quickly discharges now. I’ve gone back to my original for the time being.
The only reason why I purchased it from here was the company which I have mad respect for. But this issue isn’t their problem and we’re talking about an old phone which LG doesn’t even make batteries for. People will still come here since it’s the last phone with easy access to the battery and it’s just a great budget phone!
