LG Tribute Mid-panel Removal
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. LG Tribute Mid-panel Removal, Battery: step 1, image 1 of 2 LG Tribute Mid-panel Removal, Battery: step 1, image 2 of 2
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute Mid-panel Removal: step 2, image 1 of 1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute Mid-panel Removal, Mid-panel: step 3, image 1 of 2 LG Tribute Mid-panel Removal, Mid-panel: step 3, image 2 of 2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute Mid-panel Removal: step 4, image 1 of 2 LG Tribute Mid-panel Removal: step 4, image 2 of 2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 68
