Introduction
You may need to replace your speaker if you notice a decrease in sound quality while using your phone or while listening to music.
Use the curved opening at the center-bottom of the battery to carefully remove the old battery.
Remove the six 1.4mm screws using a Phillips head screwdriver with a size PH00 bit. Then fully remove the back panel with a plastic opening tool.
Remove the speaker from the back panel. You may have to use some tweezers if you are having a hard time grabbing the speaker with your fingers.
