LG Optimus F60 Motherboard Replacement
  1. LG Optimus F60 Motherboard Replacement, Battery: step 1, image 1 of 3 LG Optimus F60 Motherboard Replacement, Battery: step 1, image 2 of 3 LG Optimus F60 Motherboard Replacement, Battery: step 1, image 3 of 3
    • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
    • Pry or lift up on the indent with the opening tool.
    • Remove the back panel.
  2. LG Optimus F60 Motherboard Replacement: step 2, image 1 of 3 LG Optimus F60 Motherboard Replacement: step 2, image 2 of 3 LG Optimus F60 Motherboard Replacement: step 2, image 3 of 3
    • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
    • Pry upwards or lift with your finger and remove battery.
  3. LG Optimus F60 Motherboard Replacement, Motherboard: step 3, image 1 of 3 LG Optimus F60 Motherboard Replacement, Motherboard: step 3, image 2 of 3 LG Optimus F60 Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Use the Phillips #000 Screwdriver to remove the eight 4mm screws.
  4. LG Optimus F60 Motherboard Replacement: step 4, image 1 of 2 LG Optimus F60 Motherboard Replacement: step 4, image 2 of 2
    • Insert the iFixit opening tool in the indentation.
    • Pry the plastic using the opening tool to remove the lower back panel.
    • Remove the lower back panel from the device.
  5. LG Optimus F60 Motherboard Replacement: step 5, image 1 of 3 LG Optimus F60 Motherboard Replacement: step 5, image 2 of 3 LG Optimus F60 Motherboard Replacement: step 5, image 3 of 3
    • Insert the iFixit opening tool starting under the charging port.
    • Continue to pry at the edges until loose enough to remove.
  6. LG Optimus F60 Motherboard Replacement: step 6, image 1 of 3 LG Optimus F60 Motherboard Replacement: step 6, image 2 of 3 LG Optimus F60 Motherboard Replacement: step 6, image 3 of 3
    • Find the digitizer connector in the lower left hand corner of the device.
    • Use the tweezers to gently lift up and remove the connector.
  7. LG Optimus F60 Motherboard Replacement: step 7, image 1 of 3 LG Optimus F60 Motherboard Replacement: step 7, image 2 of 3 LG Optimus F60 Motherboard Replacement: step 7, image 3 of 3
    • Gently pry the motherboard from the digitizer starting from under the charging port.
    • Remove and replace the motherboard.
2 other people completed this guide.
Mohammad Mohammad
451 Reputation
3 Guides authored
IUPUI, Team S2-G5, Henning Spring 2019 Member of IUPUI, Team S2-G5, Henning Spring 2019
IUPUI-HENNING-S19S2G5
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 227
