Introduction
In this guide, you will learn how to replace the power and volume flex cables in the LG G3.
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
Pry the back cover up to separate its plastic clips.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Remove the four Phillips #00 screws (4Â mm length).
Only the bottom 6 screws (below the battery contacts)need to be removed since your only removing the bottom panel.
Remove the last screw attaching the rear camera lens to the frame.
Now use a plastic spudger to carefully remove the camera lens.
9 other people completed this guide.
