LG G3 Power & Volume Button Cable Replacement
  1. LG G3 Power & Volume Button Cable Replacement, Back Cover: step 1, image 1 of 2 LG G3 Power & Volume Button Cable Replacement, Back Cover: step 1, image 2 of 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Power & Volume Button Cable Replacement: step 2, image 1 of 2 LG G3 Power & Volume Button Cable Replacement: step 2, image 2 of 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Power & Volume Button Cable Replacement, Battery: step 3, image 1 of 2 LG G3 Power & Volume Button Cable Replacement, Battery: step 3, image 2 of 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Power & Volume Button Cable Replacement: step 4, image 1 of 2 LG G3 Power & Volume Button Cable Replacement: step 4, image 2 of 2
    • Lift the battery out of its recess and remove it.
  5. LG G3 Power & Volume Button Cable Replacement, Loudspeaker: step 5, image 1 of 1
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Power & Volume Button Cable Replacement: step 6, image 1 of 2 LG G3 Power & Volume Button Cable Replacement: step 6, image 2 of 2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Power & Volume Button Cable Replacement: step 7, image 1 of 3 LG G3 Power & Volume Button Cable Replacement: step 7, image 2 of 3 LG G3 Power & Volume Button Cable Replacement: step 7, image 3 of 3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. LG G3 Power & Volume Button Cable Replacement, Motherboard Cover Assembly: step 8, image 1 of 1
    • Remove the eight Phillips #00 screws (4 mm length).
  9. LG G3 Power & Volume Button Cable Replacement: step 9, image 1 of 3 LG G3 Power & Volume Button Cable Replacement: step 9, image 2 of 3 LG G3 Power & Volume Button Cable Replacement: step 9, image 3 of 3
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
  10. LG G3 Power & Volume Button Cable Replacement: step 10, image 1 of 3 LG G3 Power & Volume Button Cable Replacement: step 10, image 2 of 3 LG G3 Power & Volume Button Cable Replacement: step 10, image 3 of 3
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  11. LG G3 Power & Volume Button Cable Replacement, Power & Volume Button Flex Cable: step 11, image 1 of 2 LG G3 Power & Volume Button Cable Replacement, Power & Volume Button Flex Cable: step 11, image 2 of 2
    • Remove the last screw attaching the rear camera lens to the frame.
    • Now use a plastic spudger to carefully remove the camera lens.
  12. LG G3 Power & Volume Button Cable Replacement: step 12, image 1 of 3 LG G3 Power & Volume Button Cable Replacement: step 12, image 2 of 3 LG G3 Power & Volume Button Cable Replacement: step 12, image 3 of 3
    • Using the spudger, release power & volume button flex from adhesive carefully.
  13. LG G3 Power & Volume Button Cable Replacement: step 13, image 1 of 1
    • Finally, remove the flex.
9 other people completed this guide.
Sophia
43,810 Reputation
62 Guides authored
One Comment
I bought a more powerful battery. 6800 mah .instead of the 3000mah OEM . Ia there any problem using it?
mitoll - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 21,998
