Introduction
Use this guide to replace the earpiece speaker in the LG G3 (D855).
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
Pry the back cover up to separate its plastic clips.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Remove the four Phillips #00 screws (4 mm length).
Only the bottom 6 screws (below the battery contacts)need to be removed since your only removing the bottom panel.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
8 other people completed this guide.
3 Comments
unless you broke the phone, NO
