Introduction
This guide will show you how to replace the motherboard in your LG G Watch.
First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
Grasp the exposed shoulder with the tweezers to perform the next step.
Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
Use the spudger to gently lift up and disconnect the display connector.
Now use the spudger to disconnect the digitizer connector.
4 other people completed this guide.
One Comment
is it possible to replace the battery which is in the board?
Is there a reason you are removing the straps before the back of the watch? They don't block the back from coming off or really get in the way much.
Andy Wickham - Reply
its in the way, obviously it need to take them off, lol.
silentg4real -
Where can I get this battery?
Josh Wheat - Reply
where can i buy a new replacement rear case? please let me know!
silentg4real - Reply
I'd like to know as well and don't care if it's a knock off either
Joseph Wellman -
