Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
If your battery isn't working, it may be time to replace it. This guide will show you how to replace the battery.
  1. With the tablet face down, pull the SD card slot cover out. Using a Philips #000 screwdriver, remove the 3mm screw located in the SD card slot.
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Philips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. Insert a plastic opening tool in the small crevasse between the screen and the back panel. Pry the screen away from the back panel. Repeat this on each edge of the device.
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. After using the plastic opening tools, pry the device open with your hands. Remove the back panel from the screen.
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
    • Remove the four 3 mm Phillips screws that are attached to the speaker.
    • These screws are very small so make sure to keep track of them. You can use iFixit's Pro Magnetic Project Mat to help.
  4. Use your fingers to remove the speaker.
    • Use your fingers to remove the speaker.
  5. With a Philips #000 screwdriver  unscrew the 3mm screws at the corners of the battery. With a Philips #000 screwdriver  unscrew the 3mm screws at the corners of the battery.
    • With a Philips #000 screwdriver unscrew the 3mm screws at the corners of the battery.
  6. Using a spudger or plastic opening tool, disconnect the ribbon cable from the right side of the device, where it is attached with adhesive. These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead. These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Using a spudger or plastic opening tool, disconnect the ribbon cable from the right side of the device, where it is attached with adhesive.
    • These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
  7. Use the Philips #000 screwdriver  to remove the 3mm screws at the bottom of the tape. Remove the yellow tape from the device.
    • Use the Philips #000 screwdriver to remove the 3mm screws at the bottom of the tape.
    • Remove the yellow tape from the device.
  8. Unhook the battery from where it is attached at the top of the device. Unhook the battery from where it is attached at the top of the device.
    • Unhook the battery from where it is attached at the top of the device.
Mario Salguero
781 Reputation
6 Guides authored
CSU Fullerton, Team 1-6, Bruce Fall 2015 Member of CSU Fullerton, Team 1-6, Bruce Fall 2015
CSUF-BRUCE-F15S1G6
4 Members
14 Guides authored
Past 24 Hours: 10
Past 7 Days: 74
Past 30 Days: 314
All Time: 36,365
