LG Cosmos 2 Option Buttons Replacement
  1. LG Cosmos 2 Option Buttons Replacement, Battery: step 1, image 1 of 3 LG Cosmos 2 Option Buttons Replacement, Battery: step 1, image 2 of 3 LG Cosmos 2 Option Buttons Replacement, Battery: step 1, image 3 of 3
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 Option Buttons Replacement: step 2, image 1 of 3 LG Cosmos 2 Option Buttons Replacement: step 2, image 2 of 3 LG Cosmos 2 Option Buttons Replacement: step 2, image 3 of 3
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 Option Buttons Replacement, Rear Case: step 3, image 1 of 1
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 Option Buttons Replacement: step 4, image 1 of 3 LG Cosmos 2 Option Buttons Replacement: step 4, image 2 of 3 LG Cosmos 2 Option Buttons Replacement: step 4, image 3 of 3
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. LG Cosmos 2 Option Buttons Replacement, Motherboard: step 5, image 1 of 1
    • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
  6. LG Cosmos 2 Option Buttons Replacement: step 6, image 1 of 1
    • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
  7. LG Cosmos 2 Option Buttons Replacement: step 7, image 1 of 2 LG Cosmos 2 Option Buttons Replacement: step 7, image 2 of 2
    • Use the plastic opener to disconnect the ribbon cable.
  8. LG Cosmos 2 Option Buttons Replacement: step 8, image 1 of 2 LG Cosmos 2 Option Buttons Replacement: step 8, image 2 of 2
    • Use tweezers to disconnect the two cables that attach the motherboard to the case.
    • Note: Pull on the cables gently to prevent damage for future use.
  9. LG Cosmos 2 Option Buttons Replacement: step 9, image 1 of 1
    • Remove the motherboard from the front case.
  10. LG Cosmos 2 Option Buttons Replacement, Option Buttons: step 10, image 1 of 1
    • Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
  11. LG Cosmos 2 Option Buttons Replacement: step 11, image 1 of 2 LG Cosmos 2 Option Buttons Replacement: step 11, image 2 of 2
    • Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
  12. LG Cosmos 2 Option Buttons Replacement: step 12, image 1 of 1
    • Use a screwdriver and corresponding bit to remove the four 3mm screws. Set the screws aside.
    • Note: Two of the screws may be hidden underneath a black rubber film. Pull off this film if necessary.
  13. LG Cosmos 2 Option Buttons Replacement: step 13, image 1 of 2 LG Cosmos 2 Option Buttons Replacement: step 13, image 2 of 2
    • Use the plastic opener to pry open the front of the phone.
    • Slip the ribbon cable through the slit to fully separate the two pieces.
  14. LG Cosmos 2 Option Buttons Replacement: step 14, image 1 of 1
    • Use a screwdriver and corresponding bit to remove the two 1mm screws. Set the screws aside.
  15. LG Cosmos 2 Option Buttons Replacement: step 15, image 1 of 1
    • Detach the ribbon cable with the plastic opener.
  16. LG Cosmos 2 Option Buttons Replacement: step 16, image 1 of 3 LG Cosmos 2 Option Buttons Replacement: step 16, image 2 of 3 LG Cosmos 2 Option Buttons Replacement: step 16, image 3 of 3
    • Use the spudger to pry the metal piece loose.
    • Remove the metal piece along with the two ribbon cables.
  17. LG Cosmos 2 Option Buttons Replacement: step 17, image 1 of 1
    • Flip the front of the phone over and the old option buttons will fall out.
    • Insert new option buttons.
Nick White
851 Reputation
8 Guides authored
Clemson, Team 13-1, Benson Fall 2013 Member of Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Members
16 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 354
