You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
This guide explains how to remove the back cover from your LG CG225.
  1. Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
    • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
  2. Android Fix Kits
    A new screen or battery is one kit away.
    Shop Now
    Android Fix Kits
    Shop Now
  3. Remove a single Phillips #00 screw from beneath the cover.
    • Remove a single Phillips #00 screw from beneath the cover.
  4. Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
    • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
Darlena
201 Reputation
3 Guides authored
Ohio State, Team 1-2, Buehl Spring 2014 Member of Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 119
