Kyocera Event Motherboard Replacement
  1. Kyocera Event Motherboard Replacement, Battery: step 1, image 1 of 3 Kyocera Event Motherboard Replacement, Battery: step 1, image 2 of 3 Kyocera Event Motherboard Replacement, Battery: step 1, image 3 of 3
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Motherboard Replacement: step 2, image 1 of 1
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event Motherboard Replacement, Remove the screws.: step 3, image 1 of 2 Kyocera Event Motherboard Replacement, Remove the screws.: step 3, image 2 of 2
    • Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
  4. Kyocera Event Motherboard Replacement, Remove the back assembly: step 4, image 1 of 3 Kyocera Event Motherboard Replacement, Remove the back assembly: step 4, image 2 of 3 Kyocera Event Motherboard Replacement, Remove the back assembly: step 4, image 3 of 3
    • Pry the back assembly away from the body on all four sides of the phone.
    • Start prying at the top and work around.
    • Remove the buttons for the volume and power-this will allow for easier disassembly.
    • The back assembly is firmly attached to the body of the phone so removing it will require some force.
  5. Kyocera Event Motherboard Replacement, Motherboard: step 5, image 1 of 2 Kyocera Event Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • Locate the black L-shaped cover at the top center of the phone.
    • Remove the piece, including the attached ribbon, and set it aside.
  6. Kyocera Event Motherboard Replacement, Disconnect Cables: step 6, image 1 of 3 Kyocera Event Motherboard Replacement, Disconnect Cables: step 6, image 2 of 3 Kyocera Event Motherboard Replacement, Disconnect Cables: step 6, image 3 of 3
    • Use a spudger to carefully disconnect the black cable.
    • Use the spudger to carefully disconnect the brown cable.
  7. Kyocera Event Motherboard Replacement: step 7, image 1 of 2 Kyocera Event Motherboard Replacement: step 7, image 2 of 2
    • Locate the hook at the bottom of the phone. Use the spudger unlatch the hook connecting the motherboard to the front assembly of the phone.
    • Using your fingers, gently grab the motherboard and pull.
  8. Kyocera Event Motherboard Replacement: step 8, image 1 of 1
    • Prior to removing the motherboard, remove the speaker from the top of the device.
  9. Kyocera Event Motherboard Replacement: step 9, image 1 of 1
    • Using fingers, remove the motherboard from its casing.
Sydney
19 Reputation
1 Guide authored
Ohio State, Team 1-3, Michaels Spring 2015 Member of Ohio State, Team 1-3, Michaels Spring 2015
OSU-MICHAELS-S15S1G3
4 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 829
